Leap Components SRAM AXS Rear Derailleur Stealth Cage
$74.95
Leap Components SRAM AXS Rear Derailleur Stealth Cage is a lightweight replacement cage for SRAM Eagle AXS rear derailleurs, including GX, X01, and XX1. Manufactured from carbon-reinforced polyamide, it reduces weight while maintaining chain control and drivetrain performance within SRAM Eagle AXS systems.
Pulley wheels are not included. This allows riders to choose pulleys that match their drivetrain setup, bearing preference, and performance goals.
Overview
  • Replacement cage for SRAM Eagle AXS rear derailleurs
  • Compatible with GX, X01, and XX1 Eagle AXS systems
  • Carbon-reinforced polyamide construction
  • Designed to reduce weight while maintaining chain control
  • Pulley wheels are not included
  • Allows custom pulley wheel selection
  • Not compatible with SRAM Transmission, mechanical Eagle, or SRAM road AXS derailleurs
Specs
 Compatibility SRAM GX / X01 / XX1 Eagle AXS
 Material Carbon-Reinforced Polyamide
 Pulley Wheels Not Included
Compatibility Notes
This cage fits SRAM Eagle AXS GX, X01, and XX1 rear derailleurs only. It is not compatible with SRAM Transmission, mechanical Eagle, or SRAM road AXS derailleurs.
