Leap Components AXS Quickshift Shifter
$47.99
Article number: 001-03-02
Leap Components Quickshift is a replacement shifter button system for SRAM AXS wireless shifting, designed to mount under the handlebar for improved thumb access and cleaner cockpit ergonomics. Built for riders who want a more defined shifting interface than the stock SRAM rocker layout, Quickshift provides a compact under-bar control solution for compatible AXS drivetrains.
SRAM AXS Wireless Blips are not included.
Why Use Leap Components Quickshift
Under-bar shifter placement improves thumb access and reduces cockpit clutter on drop-bar setups. Quickshift replaces the stock SRAM AXS interface with a more deliberate control layout, supporting precise upshifts and downshifts from a compact position beneath the handlebar.
  • Replacement shifter interface for SRAM AXS wireless systems
  • Under-bar mounting improves thumb access
  • Ambidextrous control layout
  • Compatible with Quickshift paddles and Seatshift configuration
  • 3D Printed Carbon Filled Nylon (CF15) construction
  • Lighter than the stock SRAM rocker interface
 Configuration Paddles Seatshift
 Weight ~13.9g ~6.8g
 Interface Paddle-Based Control
 Material 3D Printed Carbon Filled Nylon (CF15)
 Dimensions 5 x 3 x 2.5 cm
Installation Video
A compact under-bar control upgrade for riders refining SRAM AXS cockpit ergonomics and shifting feel.
