Risk Titanium Front Derailleur Mounting Bolt RT112
$13.00
Article number: 017-05-02
The Risk Titanium Front Derailleur Mounting Bolt (RT112) is a precision replacement fastener for securing front derailleurs to the frame or braze-on mount. Machined from corrosion-resistant titanium alloy, it replaces the OEM steel mounting bolt while maintaining correct clamping force and alignment.
A curved, semi-arc washer designed to match the contour of common front derailleur mounting interfaces is included with the RT112. This washer distributes load evenly across the mounting surface and helps maintain derailleur alignment during setup and shifting.
Key Features
  • Titanium alloy construction for reduced weight and corrosion resistance
  • Designed for front derailleur mounting applications
  • Includes curved / semi-arc washer for proper interface alignment
  • Direct replacement for OEM steel mounting hardware
 Weight ~2.1g
 Dimension M5 x 16 mm
 Material Titanium
 Includes 1 Bolt + 1 Curved Washer
