Risk Titanium M6 Concave / Convex Washer RT064
$9.00
Article number: 017-05-02
The Risk Titanium M6 Concave / Convex Washers is a precision disc brake caliper alignment hardware designed to replace standard steel CPS (Caliper Positioning System) washers. Used between the caliper and frame or fork mount, concave/convex washers allow fine angular adjustment to center the caliper precisely over the rotor.
Manufactured from corrosion-resistant titanium alloy, these washers reduce weight while maintaining the clamping integrity required for disc brake systems. Compatible with disc brake calipers and adapters that use M6 mounting hardware and spherical washer interfaces.
 Weight ~1.1g(set) | ~2.2
 Material Titanium
 Includes 2 sets Concave / Convex Washers
 Dimension 10 mm 6.1 mm x 3 mm
