Risk Titanium Square Taper Crank Bolt RT125
$15.00
Article number: 017-05-02
The Risk Titanium Square Taper Crank Bolt (RT125) is a lightweight replacement fixing bolt for square-taper bottom bracket cranksets. Machined from corrosion-resistant titanium alloy, it replaces standard steel crank bolts to reduce weight while maintaining secure crank retention on square-taper spindles.
This bolt is designed for cranksets that use a square-taper interface with an M8 fixing bolt, common on many road, touring, commuting, and folding bike cranksets. Titanium construction improves corrosion resistance in wet or high-use environments while offering long-term serviceability.
This is a standard square-taper crank bolt, not compatible with self-extracting systems, ISIS Drive, or Octalink cranksets.
 Weight ~18.5g
 Material Titanium
 Includes 2 Bolts / 2 Rubber Seals
 Fits M8 x 15 mm
