Rox NePlusUItra Rim Strips
| Article number: | 01-03-03 |
The Rox NePlusUltra rim strip is a durability-focused evolution of the SuperDutE rim strip, using Kevlar construction for improved toughness while adding only approximately 1.5 grams per wheel. An adhesive backing helps keep the strip positioned on the rim bed during installation and long-term use.
Rim strips are designed to cover spoke holes and rim-bed features that can damage tubes or compromise tubeless systems. They do not protect against punctures caused by debris outside the tire. The NePlusUltra strip is intended for reliable long-term use on road, cyclocross, and mountain wheels.
- Adhesive backing helps prevent movement during installation
- Compatible with 700c and 29" rims; trim-to-fit for 26"
- 17 mm width
- Average weight approximately ~6 g per strip
| Attribute | Details |
| Weight | ~6 g |
| Material | Kevlar |
| Width | 17 mm |
| Use | Covers spoke holes / rim bed |
| Wheel Size Compatibility | 700c, 29", trim-to-fit 26" |
| Discipline | Road, Cyclocross, Mountain |
| * Weight listed is an average; small variations may occur. | |
Ordering Notes
Rox NePlusUltra rim strips are sold individually. Each strip is long enough for 700c and 29er wheels and can be trimmed for 26" mountain bike wheels.
