Seal-It Tubeless Tire Sealant
Seal-It Tire Sealant is made in Arizona for tubeless road, gravel, and mountain bike tires. Its ammonia-free latex formula is designed to seal punctures up to ¼ inch (6.35 mm) and can also be used in standard bicycle inner tubes.
For tubeless setup or routine top-offs, the sealant can be added through the valve stem once the valve core is removed.
