Selle SMP Dynamic Saddle
$269.00
Article number: FitWorks
The Selle SMP Dynamic is a performance-oriented saddle designed for riders who want SMP’s signature pressure-relief shape with a firm, lightly padded feel. Positioned between the wider, more cushioned Avant and the flatter, longer F30, Dynamic targets medium-to-large sit-bone widths and riders who spend extended time in a forward-leaning position.
Dynamic uses SMP’s carbon-reinforced nylon 12 shell, a deep central relief channel, and the distinctive dropped nose that reduces perineal pressure and improves blood flow during long rides. Thin foamed-elastomer padding preserves road feedback while preventing hot spots, making it well suited to endurance road, gravel, and XC riding.
At Fair Wheel Bikes, we typically stock the black cover with AISI 304 stainless-steel rails, compatible with standard 7 × 7 mm seatpost clamps. Alternate colors and carbon-rail versions are available by special order. If you’re dialing in a fit or matching a specific build, Contact us and we’ll source the exact Dynamic configuration you need.
 Rails Stainless Carbon
 Weight ~290g ~235g
 Width 138 mm
 Length 274 mm
 Saddle Rails 7 x 7 mm 7 x 9 mm
 Intended Use MTB, Road, Gravel / Cyclocross
 Material Cover Shell
  Leather / Microfiber Carbon reinforced
 Padding Material Foamed Elastomer
 Padding Level Thin
 Colors black, white, red, yellow, yellow fluo, green IT, green, light blue, blue, black lady, white lady
  • Riders wanting more cushioning and a wider platform should consider the Selle SMP Avant, while those preferring a flatter, longer profile may prefer the Selle SMP F30 or F30C.
  • Pair the Dynamic with one of our lightweight seatposts to fine-tune setback and saddle height for optimal fit.
  • Not sure if Dynamic is the right shape? Our bike fitting service can measure sit-bone width and riding position to confirm the correct SMP model.
