X-LAB Branta Integrated Carbon Handlebar and Stem
$375.00
Article number: 018-05-01
The X-LAB Branta Integrated Carbon Handlebar and Stem combines a road drop handlebar and stem in a single carbon cockpit. Developed within XDS' in-house Branta component line, its integrated aero layout creates a clean transition between the handlebar and front end of the bike.
Fair Wheel Bikes carries three width and stem-length combinations: 400 × 120 mm, 380 × 100 mm, and 360 × 100 mm. These correspond to 40, 38, and 36 cm handlebars, respectively.
Integrated Road Cockpit
The combined handlebar and stem fixes the relationship between bar position and stem length. Choosing the correct combination is therefore an essential part of establishing the riding position. The two 100 mm options allow a choice of 36 or 38 cm nominal bar width; the 40 cm option pairs with a 120 mm stem.
X-LAB lists the Branta carbon integrated cockpit across its road range, including the AD8, AD9, RT9, and RS7. Its published road-bike information describes integrated cable routing and support for two-bolt under-handlebar computer mounts. Exact frame fit, routing, and mount hardware should be checked for the supplied cockpit before installation.
Sizes Carried by Fair Wheel Bikes
Size Handlebar Width Stem Length Weight
400 × 120 400 mm / 40 cm 120 mm ~390 grams
380 × 100 380 mm / 38 cm 100 mm ~390 grams
360 × 100 360 mm / 36 cm 100 mm ~390 grams
Sizes are listed as nominal handlebar width × stem length. Current availability is shown in the product options.
Fit and Compatibility
Before ordering, confirm the cockpit's fit with the fork steerer, headset cover, spacer system, and cable or brake-hose routing on the intended bicycle. Use on an X-LAB road bike does not establish universal compatibility or interchangeability between models.
For assistance choosing a size or checking fit,
call Fair Wheel Bikes at (520) 624-3045.
