X-LAB GT8 Gravel Bike / Frame
X-LAB GT8 Consultations
Our Park Avenue Studio helps riders confirm X-LAB GT8 sizing, check availability, and plan complete gravel builds.
Call our Park Ave. Studio to discuss fit, tire setup, drivetrain options, component selection, and build direction.
The X-LAB GT8 is a carbon gravel platform designed for stability, control, and long-distance comfort across pavement, dirt roads, rough trails, and mixed-surface routes. With generous tire clearance, in-frame storage, multiple accessory mounts, electronic shifting, carbon wheels, and an integrated power meter, the GT8 arrives equipped for gravel racing, adventure riding, and short bikepacking trips.
Ride Character
- Stable and controlled on rough surfaces
- Comfort-oriented for long mixed-terrain rides
- Responsive enough for gravel racing and faster efforts
Fit & Geometry
- Balanced gravel position with confident handling
- Six frame sizes from XS through XXL
- Size-specific cockpit and crank dimensions
Clearance & Storage
- Maximum tire clearance up to 55 mm
- Integrated downtube storage compartment
- Accessory mounts on the frame and fork
GT8 Fit & Setup Options
The GT8 uses a two-piece carbon cockpit with multiple handlebar and stem options, making it easier to refine reach, width, and control placement than a fixed one-piece system. The frame also supports a broad range of gravel configurations, including 1x or 2x drivetrains, internally routed dropper posts, larger tires, and additional cargo or water storage.
Cockpit & Fit
- Branta carbon stem and gravel handlebar
- Multiple handlebar-width and stem-length options
- Standard 31.8 mm computer-mount compatibility
Drivetrain & Adventure Setup
- Compatible with 1x and 2x drivetrains
- Internally routed 27.2 mm dropper-post compatibility
- Frame, fork, top-tube, and downtube accessory mounts
X-LAB GT8 Platform Notes
| Category | Gravel / Adventure |
| Frame & Fork | Toray T800 Carbon |
| Groupset | Shimano GRX RX717 Di2 |
| Drivetrain | 1x12, 40T with 10–51T Cassette |
| Power Meter | Branta Dual-Sided Alloy Power-Meter Crankset |
| Wheelset | Branta C45 Gravel Carbon |
| Stock Tires | Continental Terra Trail 700 × 45C |
| Maximum Tire Clearance | Up to 55 mm |
| Bottom Bracket | T47 / 24 mm Spindle |
| Derailleur Hanger | UDH Compatible |
| Storage | Integrated Downtube Storage |
| Claimed Weight | ~8.78 kg / 19.31 lb, Size Medium |
| Frame Sizes | XS / S / M / L / XL / XXL |
| Build Direction | Gravel Racing / Adventure / Mixed Surface / Short Bikepacking |
X-LAB Custom Builds & Bike Features
Explore Fair Wheel Bikes custom builds, bike features, product reviews, and performance component coverage on our YouTube channel.
Contact Fair Wheel Bikes to discuss X-LAB GT8 availability, sizing, tire setup, and complete gravel build options.
