Abbey Bike Tools Decade Chain Tool
$21.00
Article number: 005-05-02
Abbey Bike Tools Decade Chain Tool is a professional chain breaker designed for consistent drivetrain service across modern bicycle chains. Built with machined aluminum handles and a cro-moly steel body, it uses a shock-rated tool steel pin capable of more than 10,000 chain breaks while maintaining precise alignment during chain installation or removal.
Compatible with 9–13 speed chains from Shimano, SRAM, and Campagnolo, the Decade Tool also includes a threaded backstop stored inside the handle for peening Campagnolo 11 and 12-speed chains. A PVD-coated lead screw and large ergonomic handles help deliver smooth operation and long service life in professional workshop environments.
Why Use Abbey Decade Chain Tool
Accurate chain installation and removal requires a chain tool that maintains alignment under load. The Decade Tool is designed to provide consistent chain breaking performance across modern drivetrain systems while minimizing pin wear and preventing damage to chain plates.
  • Designed for breaking and installing modern bicycle chains
  • Compatible with 9–13 speed Shimano, SRAM, and Campagnolo chains
  • Shock-rated tool steel pin designed for extended service life
  • Threaded backstop allows peening of Campagnolo chains
  • Machined aluminum handles improve grip and control
  • PVD coated lead screw provides smooth operation and durability
  • Workshop chain installation and chain removal
  • Professional drivetrain service
  • Mechanics working with multiple drivetrain standards
  • Precise Campagnolo chain peening when required
 Specification
 Material Aluminum Handles / Cro-Moly Steel Body
 Compatibility 9–13 Speed Chains (Shimano / SRAM / Campagnolo)
 Campagnolo Chain Peening 11 and 12 Speed Chains
 Notes SRAM AXS 12 Speed and 1/8" Chains Require Optional Mid Plate
Replacement Parts
  • Replacement Chain Pin
    • Compatible alternative to Campagnolo UT-CN300, Shimano CN-34, and CN-32 chain tools
    • Sold individually
  • Replacement Mid Plates
    • Standard — For 9–13 speed chains
    • SRAM AXS — For SRAM AXS 12 speed chains
    • Track & Single Speed — For 1/8" chains
Pairs Well With
For complete drivetrain service, the Decade Chain Tool pairs naturally with the Abbey Whip-It Chain Whip and the Abbey Crombie Cassette Lockring Tool for cassette service. Mechanics performing shifting diagnostics often combine it with the Abbey H.A.G. Hanger Alignment Gauge.
