Abbey Bike Tools Crank Pre Load Tool
| Article number: | 005-05-02 |
Abbey Bike Tools Shimano Crank Pre-Load Tool is a precision-machined aluminum tool designed for adjusting the preload cap on Shimano 24 mm spindle cranksets. CNC machined in Bend, Oregon, it uses a finger-spline profile for secure manual engagement and controlled preload adjustment during crank installation and bearing setup.
A central 6 mm hex interface allows added leverage when needed, while the compact format makes it easy to keep in a workshop drawer, travel tool kit, or fit setup. The tool also fits the Abbey Fit Kit, where its center slot accepts 8 mm or 10 mm saddle-height bullets for rider position measurement.
Why Use Abbey Shimano Crank Pre-Load Tool
Correct crank preload is important for smooth bearing operation and proper Shimano crank installation. This tool is designed to provide more secure engagement and better control than plastic preload tools, helping mechanics adjust preload caps accurately during installation, service, or fit work.
- Designed for Shimano crank preload adjustment and installation
- Finger-spline profile improves grip and alignment on preload caps
- 6 mm hex center allows additional leverage when needed
- Machined aluminum construction improves durability over plastic tools
- Compact format fits workshop, travel, and fit kit use
- Compatible with Abbey Fit Kit saddle-height bullets
- Shimano crank installation and preload adjustment
- Bearing preload tuning during workshop service
- Bike fit setups using Abbey Fit Kit components
- Mechanics who want a more durable alternative to plastic preload tools
Feature List
- Finger-Spline Profile — Provides secure manual leverage and accurate cap engagement.
- 6 mm Hex Interface — Accepts a hex key when additional leverage is needed.
- Machined Aluminum Construction — Durable, lightweight, and suited to repeated workshop use.
- Fit Kit Compatible — Center slot accepts Abbey 8 mm and 10 mm saddle-height bullets.
- Compact Format — Easy to store in tool rolls, fit kits, or bench setups.
Pairs Well With
For crank and bottom bracket service, pair this tool with the Abbey Bottom Bracket Socket Tool. It also fits naturally alongside the Abbey T-Handle Tool and Abbey 4-Way Multi-Tool for broader installation and adjustment work.
