Alpitude Navene Carbon Saddle
$350.00
Alpitude Navene Carbon Saddle is a handmade Italian full-carbon saddle designed for riders who want a very light saddle with a slightly more reinforced use profile than the Gardena. Its short, flat shape supports modern road, gravel, and XC positions while keeping the overall structure minimal and direct.
Navene uses a full-carbon shell and 7 x 9 mm carbon rails, with a claimed weight of approximately 72 g in the 130 mm version. It is the better Alpitude saddle choice when the build calls for ultralight construction but also needs a broader road, gravel, and XC use range.
Use Navene for lightweight road, gravel, and XC builds where low weight matters, but the rider wants a more reinforced use case than the Gardena. The short-fit shape works well for aggressive positions and riders who prefer a compact saddle platform.
  • Handmade in Trentino, Italy
  • 100% unidirectional carbon fiber construction
  • Short, flat profile for modern road, gravel, and XC positioning
  • Minimal full-carbon shell with tuned stiffness
  • 7 x 9 mm oval carbon rails
  • 130 mm width currently listed, with 142 mm noted as forthcoming
  • Higher rider weight limit than Gardena
 Construction Unidirectional Carbon Fiber
 Width 130 mm
 Length 245 mm
 Claimed Weight ~72 g
 Rails Full Carbon, 7 x 9 mm
 Recommended Use Road / Gravel / XC
 Max Rider Weight 210 lb / 95 kg
Fit Note: Navene is not simply a wider Gardena. It should be positioned as Alpitude’s more versatile short-fit saddle for road, gravel, and XC builds, while Gardena remains the more road/gravel-specific ultralight option.
Related Components
For another full-carbon pressure-relief saddle, compare the MCFK Open Full Carbon Saddle. Riders wanting a covered lightweight saddle can also compare the Tune Speedneedle 20Twenty Carbon Saddle.
For matching lightweight finishing parts, pair Navene with the Alpitude Superleggero Carbon Bottle Cage or Alpitude Manghen Carbon Top Cap.
