Cane Creek G4 eeBrake - Regular Mount
$389.99
Article number: 005-02-01
Cane Creek G4 eeBrake Regular Mount is a lightweight road rim brake caliper for frames using standard single-bolt brake mounts. With claimed weights of approximately 85.3g front and 83.7g rear, it remains one of the benchmark options for riders building or maintaining high-end rim brake road bikes.
The G4 design uses CNC-machined aluminum with titanium and stainless steel hardware, combining low weight with strong braking feel, clean cable routing, tool-free centering, and quick pad service.
Cane Creek G4 eeBrake Regular Mount Features
The eeBrake platform is designed around precise pad motion, fast wheel removal, and simple adjustment. The pivoting cable adjuster helps maintain cable alignment through the brake stroke, while the pad carrier system allows quick changes between carbon and aluminum rim brake pads when needed.
Brake Pad And Rim Compatibility
Carbon-compatible brake pads are included. Aluminum rim pads are available separately. The brake is designed for 19-28mm external rim widths and 39-49mm short-reach road brake applications.
Product Details And Saddle Comparison
Specs
 Mount Type Regular Single-Bolt Mount
 Weight ~85.3g Front ~83.7g Rear
 Reach 39-49mm Short-Reach Road
 Rim Compatibility 19-28mm External Rim Width
 Materials CNC Aluminum, Titanium, Stainless Steel
 Pad System Tool-Free Pad Carrier System
 Included Pads Carbon Rim Brake Pads Included
 Lever Compatibility Shimano, SRAM, And Campagnolo Road Levers
 Warranty 3-Year Manufacturer Warranty
Related Cane Creek eeBrake Products
For rotating cosmetic versions, see the Cane Creek Limited Edition eeBrake. For pad holders, replacement hardware, and maintenance parts, see Cane Creek eeBrake Small Parts.
