Gemini Scott Addict 2025 Headset Cover
$65.00
The Gemini Scott Addict 2025 Headset Cover is a frame-specific upper headset cover used to integrate compatible Gemini cockpits with the 2025 Scott Addict platform. It helps complete the cockpit-to-frame transition for clean routing and proper headset/spacer alignment.
Compatibility & Ordering
This headset cover is specific to the Scott Addict 2025 platform and should be confirmed before ordering. Final cockpit compatibility, spacer setup, routing style, and availability are verified through Fair Wheel Bikes.
Compatibility Notes
Frame Fit
Designed for the 2025 Scott Addict headset and cockpit integration layout. Confirm model year and frame version before ordering.
Gemini Cockpit Use
Used with compatible Gemini integrated cockpit systems where a Scott Addict 2025-specific upper headset cover is required.
Before Ordering
Confirm your exact frame model, frame year, headset configuration, spacer setup, and intended Gemini handlebar before ordering. Frame-specific headset covers are not universal.
Confirm Fit & Availability
Call (520) 624-3045 or email [email protected] for compatibility and availability.
