KCNC Cobweb II Road Chainring
| Article number: | 020-01-04 |
The KCNC Cobweb II Road Chainring is engineered for riders seeking a balance of low weight, stiffness, and precise shifting performance. CNC-machined from AL7075-T6 aluminum, each ring features KCNC’s signature “cobweb” cutout pattern, removing excess material for weight savings while maintaining structural integrity. Compatible with 11-speed drivetrains, the Cobweb II is hard-anodized for extended wear life and available in a range of tooth counts to match your gearing needs. Ideal for lightweight road, TT, and climbing-focused setups.
CNC-machined from AL7075-T73 for strength and stiffness
Cobweb cutouts reduce weight while preserving rigidity
Hard-anodized finish for extended durability
Optimized for precise, reliable shifting
Anodized finish for durability and corrosion resistance
| Material | Aluminum | |
| BCD | 110 | |
| Fits | ~0.9 mm - 1.3 mm | |
| Weight | ~15g | ~50g |
Pair the KCNC Cobweb II with our KCNC SL Double Road Chainring Bolts or explore ultra-light options like the Extralite OctaRamp RC2 for matching performance upgrades.
