KCNC SE Pro Lite AL75 Offset Seatpost
| Article number: | 019-02-01 |
Designed and built with the same specs as the venerable Ti Pro Lite, the SE Pro Lite Setback Seatpost from KCNC comes with 25mm of offset and is undoubtedly one of the finest setback posts available. Equipped with the same race proven titanium hardware and 7075-T6 aluminum yoke system seen on the Ti Pro Lite, the SE Pro Lite is a performance tuned seatpost ready for anything. Carefully machined from a scandium alloy tube, the SE Pro Lite represents KCNC’s versatility in design and construction. With 25mm of offset, the SE Pro Lite makes dialing in your ideal fit an effortless endeavor, while simultaneously maintaining a unique minimalist aesthetic. Budget friendly, light, and attractive, the SE Pro Lite from KCNC is sure to find a home on a range of builds from budget minded to boutique.
| 27.2 mm | 31.6mm | |
| 350mm | ~211g | ~226g |
| 400mm | ~228g | ~245g |
| Max Torque | 5Nm | 5Nm |
