Risk Titanium Shifter Hydraulic Oil Hose Bolt RT130
| Article number: | 017-05-01 |
The Risk Titanium Hydraulic Shifter Oil Port Screw (RT130) is a precision-machined replacement for the oil injection port screw used on newer road hydraulic brake levers. Titanium construction improves corrosion resistance and long-term durability while maintaining correct thread engagement and sealing depth.
Installation Note:
Always confirm lever model and port depth before installation and torque to manufacturer specifications.
| Weight | ~6g (set) |
| Tools | 8 mm Socket Wrench |
| Includes | 2 Screws |
| Dimension | M9 x 10 mm |
| Material | Titanium |
For a brake upgrade kit, check out the RT124.
For other upgrade parts, check out these cockpit or brake parts.
