Risk Titanium Shimano Shifter Clamp Screw RT120
| Article number: | 017-05-01 |
The Risk Titanium Shimano Shifter Clamp Screw (RT120) is a precision replacement fastener for securing Shimano road shifters and older SRAM to the handlebar. Machined from corrosion-resistant titanium alloy, it replaces the OEM steel clamp screw to reduce weight while maintaining reliable clamping force.
RT120 is intended for Shimano road levers that use a single clamp bolt to secure the shifter body to the bar. Titanium construction improves corrosion resistance and long-term serviceability, particularly on bikes exposed to sweat, humidity, or frequent travel.
Installation Note:
Torque to shifter specifications. Over-tightening may damage the shifter clamp or handlebar, particularly with carbon bars.
Fully Compatible (Direct Replacement)
- Shimano road shifters
Compatible With Original Washers Reused
- Shimano 5700 / 6700
- SRAM older clamp structure (partial compatibility)
- Must replace the supplied Ti washer with the OEM washer
Not Recommended / Excluded
- SRAM newer clamp designs with proprietary hardware - Use RT121
