Risk Titanium SRAM Shifter Clamp Screw RT121
$16.00
Article number: 017-05-01
The Risk Titanium Shimano Shifter Clamp Screw (RT121) is a lightweight replacement fastener set designed specifically for newer SRAM road shifter clamp systems. Machined from corrosion-resistant titanium alloy, these screws replace OEM steel hardware to reduce weight while maintaining secure and even clamp force at the handlebar interface.
RT121 is engineered around SRAM’s updated road lever clamp geometry and should only be used on compatible, newer-generation SRAM shifters. It is not backward-compatible with older SRAM clamp designs.
Installation Note:
Torque to shifter specifications. Over-tightening may damage the shifter clamp or handlebar, particularly with carbon bars.
Fully Compatible (Direct Replacement)
  • Newer SRAM road shifters using the updated clamp structure
Not Recommended / Excluded
  • Older SRAM road shifter clamp designs - use RT120
  • Shimano shifters (any generation)
 Weight ~5g
 Fits SRAM - newer shifters
 Material Titanium
 Includes 2 screws / 2 washers
