Risk Titanium Stem Clamp Screws RT131
| Article number: | 017-05-02 |
Risk Titanium Stem Clamp Screw (RT131) is a precision M5 x 16 mm replacement bolt set for bicycle stem clamp applications. Machined from corrosion-resistant titanium alloy, it replaces standard steel stem bolts to reduce weight while maintaining proper clamping force at the handlebar or steerer interface.
RT131 is intended only for stems that specify M5 x 16 mm fasteners. Correct bolt length is critical for safe stem clamping. Longer bolts may bottom out before proper clamping force is reached, while shorter bolts can reduce thread engagement.
Installation Note: Always confirm the stem manufacturer’s specified bolt length and torque values before installation. Over-length bolts can bottom out, while under-length bolts can compromise clamping safety.
For a brake hardware upgrade, see the Risk Titanium Brake Bolt Kit RT124.
For additional replacement hardware and upgrade parts, browse our cockpit service parts and brake service parts.
