SRAM eTap Brake Hoods
$45.00
Article number: 001-05-01
High‑grip, ergonomic rubber hoods designed to fit SRAM eTap brake/shifter levers. Each SKU is tuned to fit that exact lever geometry—ensure correct compatibility. Sold in left/right pairs for four specific configurations:
Red eTap HRD hydraulic levers
Red eTap mechanical rim‑brake levers
Red / Force AXS hydraulic levers
Red / Force AXS Rim‑Brake Levers
These OEM hoods provide secure grip even under wet or muddy conditions. The textured rubber is designed for endurance riding and cyclocross, but high friction use may require seasonal replacement. Frequent checks for tears, wear, or slipping are recommended to maintain braking control and prevent accidents during intense riding.
For older SRAM 11-speed and 10-speed rim-brake models, see our SRAM Rim Brake Hoods for compatible options.
 Compatibility Mfg. Part # Weight
 Red eTap 00.7918.066.000 ~40g
 Red HRD 00.7918.027.002 ~54g
 Red / Force Rim Brake 00.7918.084.000 ~40g
 Red / Force Hydraulic 00.7918.083.000 ~56.5g
