THM Tibia Road ICR Carbon Stem
THM Tibia ICR Carbon Road Stem is an ultralight performance stem engineered for modern road bikes using internal cable routing. Built with THM’s proprietary carbon construction process, it delivers exceptional stiffness, precise steering response, and class-leading weight for high-performance road setups.
Designed for today’s integrated front ends, the Tibia ICR is compatible with both D-shaped and standard headset exit routing, allowing it to work across a wider range of modern frames and cockpit configurations. A four-bolt faceplate helps distribute clamping force evenly across the handlebar, while titanium hardware keeps overall weight exceptionally low.
For riders building a premium lightweight cockpit, the Tibia ICR combines low mass, refined road feel, and THM’s high-end German manufacturing standards into one of the most advanced carbon stems available.
ICR-Ready Design
Compatible with modern internal cable routing systems for clean integration on contemporary road frames.
Full Carbon Construction
Stem body and faceplate are built using THM’s advanced carbon fiber molding and layup process.
Low System Weight
Engineered to minimize cockpit weight while maintaining the stiffness and strength required for precise handling.
Four-Bolt Faceplate
Even bar clamping helps reduce localized stress and supports secure installation with carbon handlebars.
Titanium Hardware
Selected hardware keeps weight down without compromising fastening reliability.
Made in Germany
Handcrafted to THM’s exacting standards for premium lightweight road applications.
| Specification | |
| Length Options | 80 mm, 100 mm, 110 mm, 120 mm |
| Weight | ~80g (80 mm), ~90g (100 mm), ~94g (110 mm), ~99g (120 mm) |
| Angle | -6° |
| Handlebar Clamp Diameter | 31.8 mm |
| Stem Material | Carbon Fiber |
| Faceplate Material | Carbon Fiber |
| Hardware | Titanium |
| Maximum Bolt Torque | 4 Nm |
| Rider Weight Limit | 243 lbs. / 110 kg |
| Routing Compatibility | D-Shaped And Standard Headset Exit Routing |
| Recommended Use | Road |
Cockpit Pairing
Looking for a matching handlebar? Pair the THM Tibia ICR with the THM Ulna Carbon Road Handlebar for a clean, lightweight cockpit built around THM’s carbon road platform.
