Bjōrn Kort Saddle
Björn Kort Saddle is a short-nose carbon saddle with a 3D-printed multi-zone pad, built for riders using aggressive road, gravel, triathlon, or TT positions. At approximately 117g, Kort combines a carbon shell, reinforced rail interface, and printed support structure in a compact platform designed for forward-rotated riding.
The shorter 220mm length and wider front support area help reduce inner thigh interference while improving stability under load. Compared to Björn’s longer Setka 3D-printed saddle, Kort is the better choice for riders who spend more time in aero or aggressive positions.
- Short-nose carbon saddle with 3D-printed multi-zone pad
- Optimized for aggressive road, gravel, triathlon, and TT positions
- Compact shape reduces inner thigh interference near the nose
- Wider front platform improves support in forward-rotated positions
- Carbon shell with reinforced rail interface
- Oversized 7 x 9 mm carbon rails
- Approximate weight of 117g
Kort is best for riders who prefer a short-nose saddle and spend meaningful time in a forward, aggressive position. It is especially useful for road racing, triathlon, TT, and performance gravel setups where stability near the front of the saddle matters.
Product Details And Saddle Comparison
| Specs | Kort | Setka |
| Saddle Type | Short Nose | Traditional Length |
| Weight | ~117 g | ~137 g |
| Length | 220 mm | 250 mm |
| Nose | 40 mm | 37 mm |
| Rails | 7 x 9 mm | |
| Shell | Carbon | |
| Pad | 3D-Printed Multi-Zone | 3D Printed |
| Weight Limit | 120 kg / 264 lbs | |
| Best Use | Aero Road, Triathlon, TT | Road, Gravel, Endurance, XC |
Cross-Linking Suggestions
Compare Kort with the Björn Setka Saddle for a longer 3D-printed saddle shape designed around more traditional road and gravel positions.
For a more minimal ultralight setup, view the Sedlo Saddle. For riders who prefer padding, compare the Probka Saddle or the upcoming Divan Saddle.
