Cane Creek eeBrake Ltd. Ed. Brakeset
Cane Creek Limited Edition eeBrakes use the same lightweight regular-mount eeBrake platform as the standard model, with rotating cosmetic finishes produced in limited runs. The current version is the JPS Limited Edition, finished in a black-and-gold motorsport-inspired layout.
This page is maintained as a living Limited Edition eeBrake listing. Future Cane Creek color releases can be added here because the brake structure, fit, and performance remain the same while the finish changes.
Cane Creek Limited Edition eeBrake Overview
The eeBrake is known for low weight, precise pad adjustment, tool-free centering, quick wheel removal, and clean cable routing. Each caliper is CNC machined from high-grade aluminum with titanium and stainless steel hardware, then assembled for road rim brake frames using standard single-bolt brake mounts.
Current Limited Edition Finish
Current Version: JPS Limited Edition
Finish: Black / Gold
Platform: Regular Mount eeBrake
Use: Lightweight road rim brake builds, custom bikes, and collector-level component packages
Product Details And Saddle Comparison
| Product Details | |
| Brake Type | Road Rim Brake Caliper Set |
| Mount Type | Regular Single-Bolt Mount |
| Current Finish | JPS Limited Edition Black / Gold |
| Claimed Weight | ~169g Per Pair Without Pads |
| Rim Compatibility | 19-28mm External Rim Width |
| Reach | 39-49mm Short-Reach Road |
| Materials | CNC Aluminum, Titanium, Stainless Steel |
| Included Pads | Carbon Rim Brake Pads Included |
| Warranty | 3-Year Manufacturer Warranty |
Related Cane Creek eeBrake Products
For the standard finish, see the Cane Creek Regular Mount G4 eeBrake. For pad holders, small hardware, and replacement service parts, see Cane Creek eeBrake Small Parts.
