Praxis Wave 1x 104 BCD Mountain Chainring
Article number: | 28-05-02 |
Since their debut in 2007, Praxis Works has been a trailblazer in the cycling world, renowned for crafting top-tier chainrings. Meticulous in design and construction, Praxis consistently delivers performance that rivals or surpasses competitors. The latest addition to their lineup, the mountain rings, showcases the innovative Wave tooth profile by MRP. Balancing chain retention akin to Narrow Wide rings with alternating contact faces, these rings excel in mud and debris shedding. At 4.5mm thickness, they offer optimal stiffness for aggressive rides while maintaining a weight within XC class standards. The durability quotient is unmatched, thanks to the application of Cold Forging and Hard Anodizing processes to each ring. Elevate your biking experience with Praxis – where precision meets durability, and innovation is the norm.
For flawless performance even under the most demanding conditions pair your Wave chainring with one of Praxis Works Chain Guides for ideal chain retention.
Material | Machined 7000 Aluminum Hard Blk Anodized | ||
Recommended Rear Derailleur | Requires Clutch Type Derailleur Shimano Shadow Plus / SRAM Type 2 or Upper Chain Guide | ||
Crank Compatibility | 4-bolt 104 BCD crank | ||
Chain / Drivetrain Compatibility | 10 / 11 / 12 Speed - Shimano, SRAM, KMC | ||
Weights | |||
30t | ~32g | * threaded, needs M8 x 7.5mm bolt | |
32t | ~34g | ||
34t | ~51g | ||
36t | ~64g |
SHIPPING
Due to restrictions from International distributors we are not allowed to ship Praxis products to addresses in the following countries: Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
