Risk Titanium XT / SLX Brake Lever Piston RT126
| Article number: | 017-05-01 |
The Risk Titanium XT / SLX Brake Lever Piston (RT126) is a precision replacement master-cylinder piston for select hydraulic disc brake levers. Machined from titanium alloy, it replaces the original aluminum or composite lever piston to improve corrosion resistance, dimensional stability, and long-term durability under repeated braking cycles.
This piston is designed for Shimano XT (M8000 / M785) and SLX (M7000) hydraulic brake levers that share the same internal master-cylinder architecture. It is intended for service, rebuild, or performance-focused maintenance where consistent lever feel and longevity are priorities. Seals are reused or replaced separately per manufacturer service guidelines.
| Weight | ~5.5g |
| Fits | Shimano XT (M8000 / M785) | SLX (M7000) |
| Material | Titanium |
| Includes | 1 Piston Rod + 2 Spare O-rings |
