THM Rim Brake Pad Holders
$75.00
Article number: 014-05-03
The THM Ultralight Brake Pad Holders combine CNC-machined aluminum bodies with titanium hardware for premium road rim-brake systems where low weight, precise fit, and clean construction matter. Minimal branding and a claimed weight of approximately 9.5 g per pair make them a refined upgrade for lightweight road builds.
Each set includes one pair of brake pad holders, enough for either a front or a rear brake caliper. Two sets are required to equip a complete front and rear brake system.
Specs
Weight ~9.5 g Per Pair
Quantity 2 Holders / One Brake Caliper
Brake Pad Compatibility Shimano-Standard Road Brake Pad Inserts
Holder Material CNC-Machined Aluminum
Hardware Titanium
Quantity & Installation
THM brake pad holders are sold as a pair for one brake caliper. Order two pairs when replacing the holders on both the front and rear brakes.
Always use brake pad inserts approved for the wheel or rim braking surface. This is especially important when switching between aluminum and carbon rims.
These holders accept Shimano-standard road brake pad inserts, providing access to a wide range of compounds for aluminum and carbon braking surfaces.
View compatible SwissStop rim brake pads, or pair the holders with the THM Fibula Carbon Road Brake Set.
