Extralite CyberRear SPD-3+ Road Disc Hub
$519.95
* Unit price: $499.00 /
Article number: 010-02-03
The Extralite CyberRear SPD-3+ is among the lightest road disc rear hubs in production, weighing just ~140 – 146g depending on freehub standard. Machined in Italy from aerospace-grade 7075TX aluminum and Grade 5 titanium, it blends ultralight construction with durability for competitive road disc builds.
Its straight-pull, cross-laced spoke interface equalizes tension and enhances lateral stiffness under power and braking. The freehub body uses a dual-pawl mechanism with a 32-tooth drive ring, delivering fast engagement and efficient power transfer.
Extralite’s micro-tuner system enables precise bearing preload, ensuring zero play with minimal friction. Available with stainless steel or ceramic bearing upgrades (HDC or XD15), the CyberRear SPD-3+ is EN-tested and approved for riders up to 200 lbs (90 kg).
SERVICE
Due to the lightweight construction of Extralite hubs, it is recommended that service be performed at frequent intervals to ensure proper function and the longest possible wear life of the internal components. Detailed service instructions can be found here. We recommend Extralite's Alugrease or Buzzy's Slick Honey for proper and effective lubrication of the seals and freehub mechanism.
WHEEL BUILDING
Trust a skilled wheelbuilder for Extralite hubbed wheels. We offer expert service and rim/spoke advice. Contact us for custom wheels.
 Weight ~140g
 Spoke Holes 24h
 Axle Standard 12 x 142 mm
 Bearing Size 6903 - (1)* / 6803 - (1)*
 Brake Interface 6-Bolt
 Freehub Engagement 32t
 Material 7075T6 Aluminum, Grade 5 Titanium
*Can be ordered with either XD15 Ceramic, HDC Ceramic, or 440c Stainless Bearings
CyberRear Freehub Options
 Shimano Road 11Spd
 SRAM XDR
 Campagnolo N3W
  Road 11 / 12 Speed
--Wheel Building Dimensions--
  LEFT RIGHT
 Flange Diameter 33.0 mm 52.0mm
 Center to Flange 35.0 mm 20.0 mm
 Spoke Hole Offset 1.5 mm
 Spoke Hole Diameter 2.8 mm
*for accurate spoke lengths, please use Extralite's Cyber SPD3 hub Lacing Instructions
