Gemini Pinarello Dogma F 2024 Headset Cover
$65.00
The Gemini Pinarello Dogma F 2024 Oval Headset Cover is a frame-specific upper headset cover for integrating compatible Gemini cockpits with the 2024 Pinarello Dogma F oval headset interface.
Compatibility & Ordering
This headset cover is specific to the Pinarello Dogma F 2024 oval headset interface. Final compatibility, spacer setup, routing style, and availability should be confirmed before ordering.
Compatibility Notes
Frame Fit
Designed for the Pinarello Dogma F 2024 oval headset layout. Confirm exact frame generation before ordering.
Gemini Cockpit Use
Used with compatible Gemini integrated cockpit systems where the Dogma F oval headset cover is required for clean fit and routing.
Before Ordering
Confirm your exact Dogma F model year, headset shape, spacer setup, and intended Gemini handlebar before ordering. Oval headset covers are frame-specific and are not interchangeable with standard round headset systems.
Confirm Fit & Availability
Call (520) 624-3045 or email [email protected] for compatibility and availability.
