Abbey Bike Tools 4-Way Multi-Tool
$42.00
Article number: 005-05-03
Abbey Bike Tools 4-Way Multi-Tool delivers professional-level fastener engagement in a compact format designed for roadside adjustment and travel tool kits. Precision machined in Bend, Oregon from US-drawn aluminum alloy, the chassis holds four replaceable magnetic WERA stainless steel bits for accurate engagement with modern bike fasteners.
At approximately 48 g, the 4-Way Multi-Tool balances low weight with durable construction and precise bit fit. Its slim profile fits easily into a saddle bag, jersey pocket, or tool pouch, making it a practical tool for riders and mechanics who need reliable adjustment capability away from the workshop.
Why Use Abbey 4-Way Multi-Tool
Compact multi-tools are often limited by poor bit engagement and soft materials that damage fasteners over time. The Abbey 4-Way Multi-Tool is designed to provide accurate engagement with common hex and Torx bolts, helping reduce rounding while giving riders a lightweight tool for on-bike adjustment and emergency service.
  • Designed for roadside bike adjustment and travel tool kits
  • Precision WERA stainless bits improve fastener engagement
  • Compact 4-way design provides quick access to common bolts
  • Replaceable magnetic bits allow long-term serviceability
  • Lightweight aluminum chassis balances durability and portability
  • Made in Bend, Oregon
Feature List
  • Replaceable Magnetic Bits — Bits can be swapped or replaced as needed.
  • Precision WERA Stainless Steel Bits — Designed for tight engagement with modern fasteners.
  • Compact 4-Way Layout — Provides leverage while remaining pocket-friendly.
  • Corrosion Resistant Construction — Aluminum chassis and stainless bits resist rust.
  • Multiple Configurations — Available with different bit combinations for common bike setups.
 Specs
 Weight ~48 g / 1.76 oz
 Dimensions ~107 × 82 × 14 mm (4.2 × 3.2 × 0.55 in)
 Chassis Material Aluminum Alloy
 Bit Material WERA Stainless Steel
 Bit Type Replaceable Magnetic Bits
 Origin Bend, Oregon, USA
Pairs Well With
For greater leverage during workshop adjustments, pair the 4-Way Multi-Tool with the Abbey Bike Tools T-Handle Tool. Riders performing drivetrain service may also combine it with the Abbey Decade Chain Tool or the Abbey Crombie Cassette Lockring Tool as part of a complete tool kit.
