Alligator Centerlock Adapter
$26.40
* Unit price: $26.40 /
Article number: 009-03-04
Alligator Centerlock Adapter allows a standard 6-bolt ISO disc rotor to be used on compatible Centerlock disc brake hubs. This is useful when upgrading wheels, reusing an existing 6-bolt rotor, or choosing from rotor options that are not available in a Centerlock version.
The two-piece aluminum design uses an oversized lockring to clamp the rotor securely onto the Centerlock spline interface. It is designed for 15 mm and 20 mm thru-axle hubs and is also compatible with quick-release hub setups.
Compatibility Notes
This adapter is for mounting 6-bolt ISO rotors to compatible Centerlock hubs. Rotor thickness at the bolt flange must be at least 1.7 mm. Always confirm rotor, hub, frame, fork, and brake caliper clearance before riding.
 Rotor Fitment 6-Bolt ISO Rotor To Centerlock Hub
 Hub Compatibility 15 mm / 20 mm Thru-Axle And Quick Release
 Minimum Rotor Thickness 1.7 mm At Bolt Flange
 Maximum Rotor Size 203 mm
 Weight ~29.5 g
 Material Aluminum
 Tool Interface Hollowtech II Style BB Tool
 Recommended Torque 40 Nm
Installation Notes
Install the rotor evenly on the adapter, confirm full spline engagement, and tighten the lockring to 40 Nm using a compatible external bottom bracket style tool. Recheck brake caliper alignment after installation.
For related brake setup options, see the KCNC O/S Centerlock Adapter, KCNC Razor Disc Rotor, or Ashima Centerlock Rotor.
