ENVE Fractal Lock-on Grips
| Article number: | ENVE-2-3 |
The ENVE Fractal Lock-On Trail Grip uses a left- and right-specific ergonomic profile designed to provide secure hand placement and controlled traction for trail and enduro riding. Debossed hexagonal sections beneath the thumb and forefinger create softer high-contact zones while maintaining support through the remainder of the grip.
Available in 31.5mm and 34.5mm diameters, the Fractal allows riders to select grip thickness based on hand size and preference. Both versions use a secure lock-on installation and measure 135mm long.
Why Use The Fractal Lock-On Grip
The Fractal combines two diameter choices with directional ergonomics and strategically shaped contact zones, allowing riders to select the hand feel that best suits their riding and cockpit setup.
- Left- and right-specific ergonomic grip profiles
- Debossed hexagonal zones provide a softer feel at key contact points
- 31.5mm and 34.5mm diameter options
- 135mm overall length
- Secure lock-on installation
- Designed for trail and enduro riding
