Grigio T1000 Carbon Road Crank
The Grigio Carbonio Road Crankset is one of the lightest production cranksets available, weighing just ~240 g. Constructed entirely from T1000 high-modulus carbon fiber—including arms, spindle, and spider—it delivers unmatched stiffness at minimal weight. The only alloy element is the precisely machined aluminum preload ring, ensuring reliable adjustment.
Designed around a 5-bolt 110 mm BCD spider, the crankset supports compact and mid-compact chainrings. With its refined balance of extreme weight savings, structural rigidity, and elegant execution, this crankset is built for riders demanding the absolute minimum mass without compromise in efficiency.
- Ultra-lightweight crankset: ~239 g complete
- Constructed from T1000 high-modulus carbon fiber
- BCD 110 mm for wide chainring compatibility
- Optimized stiffness for efficient power transfer
- Alloy reinforcement at pedal and spindle interfaces
- Designed for road racing and high-performance climbing builds
| Specs | |
| Weight | ~240 g (complete crankset) |
| Material | T1000 High-modulus Carbon Fiber |
| BCD | 5-Bolt - 110 mm |
| Chainline | 44.5 mm |
| Q Factor | 148 mm |
| Discipline | Road |
| Bottom Bracket | 30 mm Spindle (Drive / Non-Drive) |
| Use Case | Climbing builds, lightweight road race bikes |
Looking for ultralight finishing components?
Pair the Grigio Carbonio crankset with the Schmolke TLO Carbon Seatpost
or THM Tibia ICR Carbon Stem for a complete lightweight cockpit.
For drivetrain integration, see our Carbon-Ti EVO Chainrings
or Extralite Octaramp.
