Risk Titanium Shifter Hydraulic Oil Injection Port Bolt RT129
$10.00
Article number: 017-05-01
The Risk Titanium Hydraulic Shifter Oil Port Screw (RT129) is a precision replacement for the oil injection port screw used on select road hydraulic brake levers. Machined from corrosion-resistant titanium alloy, it replaces OEM steel hardware to improve durability and resistance to corrosion from brake fluid exposure.
RT129 is intended for specific lever generations where oil port depth and thread engagement differ from earlier designs. Correct selection is critical to ensure proper sealing during normal use and brake bleeding.
Installation Note:
Always confirm lever model and port depth before installation and torque to manufacturer specifications.
 Weight ~2.5g (set)
 Tools 3 mm Hex Wrench
 Includes 2 Screws
 Dimension M7 x 4 mm
 Material Titanium
For a brake upgrade kit, check out the RT124.
For other upgrade parts, check out these cockpit or brake parts.
