$142.00
Article number: 008-06-03
The Carbon-Ti X-Hub Road SP Front hub features an oversized 7075-T6 aluminum body and axle, fully CNC machined for precision and strength. Designed for radial lacing, it includes an external bearing preload adjustment for optimal rotation and longevity. Weighing just 62 grams, this Italian-made hub balances low weight and durability. It has a polished, anodized finish in various colors. With high-quality 6803 bearings, a 5 x 100mm quick release axle, and 20 or 24 spoke holes, it's ideal for lightweight, reliable wheels. Serviceability is easy, perfect for performance-focused riders.
Here at Fair Wheel we choose high quality components for their intended job and strengths. The X-hub is a durable high performance hub that also happens to be light. At 62.1 grams the hub isn't as light as the Extralite CyberFront but it is 47 grams lighter than the work horse DT Swiss 240s.
WHEEL BUILDING
 Weight ~62g
 Spoke Holes 20h / 24h
 Axle Standard QR - 5 x 100 mm
 Bearing Size 6803 - (2)
 Brake Interface Rim Brake
 Flange Diameter 30.0 mm
 Center to Flange 40.0 mm
 Spoke Hole Diameter 2.4 mm
